Impeller and Headgasket Question
rl29
Help guys:<br />Getting boat ready for spring and changed <br />t-state and impeller on a force 125. Anyways hooked muffs up and got water coming out of drain holes in lower unit. Do you suppose that I don't have tube hooked up right in water pump. Was wondering if a guy can pull down that bottom water inlet seal on tube to get it to fit in the waterpump housing better. I didn't do that when I put the lower unit on. Guess I'm thinking its coming from there. I did have water coming out of the tail tail after t-state opened up but not like it was last fall so shut it down. What do you all think? <br />Also I notice water was dripping off the bottom side of the head on the starboard side under the power packs. Did I do something when I put the t-stat in or do you think the head gasket is gone. Could sure use someone elses opinions on this one. Is there someway to check something on this? Thanks though but am kind of lost or should I say not real sure what to do from here other than to pull that lower unit back down. Can use all the help I can get on both these problems. Thanks!!! :confused: :confused:
