tdunakey2951
Thread starter- Joined
- Aug 5, 2008
- 31
First off I'm sorry if I'm in the wrong area for this. But I was on here a long time ago because the Bayliner I have wouldn't get on plane if it had four people in it unless someone went and sat on the bow it would. But trim tabs and a new prop helped it a little but not really I'm 99.9% sure the flotation foam is waterlogged because there are soft spots in certain areas. But any way thats not my problem right now. My problem is someone started it out of the water and everyone said if you don't see like a pee stream the impellar is bad but the thing is it runs great doesn't get hot and hasn't lost any power that I can tell. Is there anything I should check to see if its bad or be worried about? Obviously I can't do it right now with snow on the ground its just something I have put off for too long and want to get around to fixing it if there is something wrong.
