impellar change on omc 4.3
mygalaxie
im working on changeing the impellar on my omc 4.3 model 986032 its on a 93 galaxie 4.3 1950v so the question is where do i begin a link on spliting the outboard to access the impellar pump would be very helpful cause i got no idea how this is done. im not geting water up top at t stat housing using water mufffs on outboard i read around the forum a bit and read about possible blockage in the line going to water pump also what is the impellar pump or kit i need to be shopping for im really wanting to get this project on the lake thanks all
Re: impellar change on omc 4.3
To remove the impellar (raw water pump) you have to remove the out drive top cover, just a couple bolts.. I had the same problem with muffs out of water, ruined a new raw water impeller. I gave up and took it to the river to see and it worked, I don't trust muffs!!!! After that I took the impeller off and hooked my muffs up and water never got to the input of the impeller, muffs to big???? All I know is that it stays cool all day in the lake lol
