Impact wrench on flywheel nut?
dick
Re: Impact wrench on flywheel nut?
BAD , DON'T DO IT . THE HAMMERING OF THE IMPACT COULD BREAK THE MAGNETS GLUED TO THE FLYWHEEL LOOSE.
Trent
Iv done it a million times and never seen a magnet come off.. Usually the nut just spins right off. But do not install the nut with one. Use a torque wrench.
12Footer
I've had to use an impact on the flywheel puller. It was the only way to get it off.
almost retired again
I do it all the time and have never had any problems,sure beats using a flywheel holder and using a big wench at the same time. While I,ve got the impact wrench I also pull the flywheel off . Seems to save alot of time. Could be that I,ll get bit someday though.
petryshyn
Ditto...I do it all the time too, but I must admit
does make a good point. Not only might it rattle them loose, but if you do it several times, you'll weaken the magnets. Taking the nut off usually comes on the first hit, so its no biggy, but when you rap a zillion time with a puller, there is risk involved.<br /><br />just my small opinion :(
ODDD1
Haven't messed up any of the last thousand I have yanked... I think your OK...
