cookie528i
- Mar 31, 2012
- 11
Hello everyone
I have recently bought a bayliner Capri cuddy with I/0 mercruiser 3.0 engine and alpha out drive 1990 model
I found that the breather pipe from the top of the rocker cover to the air filter was blocked with curdled oil and the pipe was bent so far that there wasn't a great space either. Inside the rocker there was emulsified oil too
I have now stripped the engine apart to check the head gasket and there is no obvious signs of wear and no cracks to be seen anywhere
The gasket for the riser and the exhaust manifold didn't look to great can this be letting in the water
Ahhhhhhhh. Where do I go from here
Thanks
Thanks
