I have pretty much been an inboard person except for a couple of experiences years ago, the Johnson 70 was great but the Sea Drive 150, well nuff said.
Given the rave reviews of these newer models and the fact that my back can't take the bilge work like it used to, I purchased a new boat with twin F150s. It was a leftover, in fact very leftover to the tune of a year and a half. Dealer said they had techs and come to find out they do not so I am stuck hauling the boat to another city or fixing it myself.
I have a few questions for the experts.
What is the normal operating temperature when running at cruising speed? Both of mine creep up an entire quadrant on the temp gauge over readings at low speed operation. No alarms going off but it is three quarters of the way across the Yamaha gauge. I'm concerned about the water pumps as I know a "service person" ran both the engines using the flush fitting.
Has anyone figured out a way to easily put those red rings back on the filter, and keep them there after cleaning the thing? I had struggled with the originals but at least they stayed on once the bowl is in place. Today I replaced both front engine mounted filters with new ones I could get only one to remain on those plastic legs even after the bowl was affixed.
These engines seem to eat filters, man, it is expensive to change all of them. I have one engine that will not run past 5600 RPM, other one runs 6100. I took the VST apart yesterday, that was a treat. The HP fuel pump filter was perhaps 20% covered with a fine white material of some nature. Hopefully that will give me the RPMs that are missing. The boat has not run correctly since I purchased it but Yamaha has been great in providing me with support. Fuel pressure is within specs. There was, however, some debris in the VST tank. Not certain how it got there.
One of the two engines has a bit of an intermittent "whine" to it, especially at low idle. Sounds like a belt issue but I hear it much lower. Could be the drive shaft? Never noticed it before but then normally don't run with the covers off.
Switched to Racor 10 micron with the clear bowl, may go to the 2 micron given the fuel is so crappy these days. I can't understand how stuff makes it's way past a 10 micron but it was there.
Plan on running her this weekend to see if the fix worked. Picture compares the port with starboard water separator mounted in boat. Not certain if this would be enough crud to cause the RMP loss. Leaning more toward the VST filter I changed.
