ziggy
- Jun 30, 2004
- 7,473
ok, i got a good floor. been replaced in 98. it's causein me greif cuttin it as it is still good wood. the red is my rotton stringers. drilled me a few holes to confirm. it's wet and dust. the yellow is dry foam. the blue is where the last creaton frickinized and built inward of the oem engine well. starboard side is intack. port side is cut out. orange is rotton cross members going from one stinger to the other. black is the motor mount board. the start of this hole hosein. it apears to go from stringer to stringer. and has 2 layers. the old and the new.
where should i be cuttin here? should i just get down and cut right on up to the transom, and the insides of the hull. gettin rid of the good foam, and good floor right out to the inside edge of the hull? this boat has spent stringers. i haven't got to the edge yet. are there stringers out there too? or is it just glassed into the edge of the hull?
i'm haveing fun now.......not......how many years. can i keep motivated?
