djpoling214
Thread starter- Joined
- Jun 16, 2011
- 9
I recently bought a 1977 Regal Cuddy Cabin (for under a grand) and its a beautiful boat for its age.
The engine has less than 20 hours on it and the it has a new Alpha 1 outdrive - I was told it was a fresh water block? Does that make sense?
Anyway, long story short, I purchased the boat brought it home and noticed the oil looked like a milk shake, the oil level was also 2-3 inches above the full line - obviously there is water in there.
The engine starts up right away, there is no smoke coming from the engine and there is no tapping. I used a pump to syphon the milky oil out - I didn't drop the oil pan, so I'm positive there is still some milky oil in there, even if it is just on the walls or where ever it could be. I replaced the oil and put a new filter on it and let it run for about 20 minutes. The engine was ran the same, started right away, no smoke, no tapping. I checked the oil and noticed it was still milky. I assume it's because there was still milky oil left in there.
I did a compression test on each of the spark plugs and the reading on each one was between 120 and 130. Tomorrow I plan on draining the oil out again and putting new oil and a new filter in and letting it run for about 20 minutes to see if the oil clears up at all.
I've talked to a few people regarding this issue, and I was told if the block was cracked, there would be tapping, some smoking and the engine could have trouble turning over. I was also told that the head gasket is probably fine due to the 120-130 compression range. So now I'm thinking it could be the exhaust manifold and riser. When I have the boat running, the riser remains cold, which I'm told is a good sign.
I'm thinking either the exhaust manifold has to be replaced or that the engine was submerged in water - in which case I was told to keep changing the oil and letting it run until the milky oil goes away.
I took the original milky oil that was in the boat to a shop and they tested it and determined that there was water and gasoline in the oil - which is probably why the oil smelled of gasoline.
Anyway, I'm at a loss. I really want to get this boat out on the water and do some fishing but I'm afraid to chance destroying the motor... And I'm certainly not paying a shop $125/hour to look over the boat to find the problem. From what I've said, what do you think the problem could be? Do you think I can take this boat out and do some fishing after a few more oil changes or should I have someone look over it and chance spending a lot of money just to hear it's not worth fixing, or it's going to cost thousands to fix...
I need help!
Thanks in advance.
I need help!
Thanks in advance.
