I'm an owner! 1975 Islander 22
paparoof
Re: I'm an owner! 1975 Islander 22
Congrats on the boat. I know what the feeling is like Mine is going on 2 weeks now for me. Been on the river 1 day..in the shop now, but minor stuff..just no time to do myself..
Hey you've been in the water! You're ahead of me! The only time my boat gets wet is when it rains!
paparoof
For me anyway, mulling is half the fun. Doing the work is the other half. And going out on the water is the other half! ;)
That sounds like the Car Talk guys - "and for the third half of our show...."
paparoof
Wow my boat got wet tonight! We had some serious weather come through here tonight. Like hail the size of a quarter hammering the roof of my car while I was driving the kids home tonight. I had the kids holding $2000 Cisco routers over their heads in case the hail came through the roof. I'm gonna have to drive over to visit the boat in the morning to see if it survived. I'm not sure they got hail there, but there's a few old willows near it and old willows don't hold up well in heavy weather. I lived in that house for 7 years and we lost three willows in that time. Fingers crossed. That reminds me, gotta buy a chain saw tomorrow anyway. Gotta tree to cut down so I can back the boat into it's new spot.
ANYHOO...
I actually had to use my new bilge pump tonight to save an egress window in our basement. The gutters were clogged :redface: and spilling over directly above the window well and it was filling up quickly. Water was 8" up the sides of the window and had little waves in it! In the hammering rain, I set down the boat battery, wired up the bilge pump, dropped it into the window well and pointed the hose at the neighbors house. 30 seconds later the well was dry. Did I tell you how cool my new bilge pump is? The kids thought it was awesome. Then we had a little stream of water about 1cm in diameter come popping out of a cinder block wall in the basement - it looked just like in the movies when that first little stream of water comes shooting into a submarine right before the walls cave in. I patched that up with hydraulic cement I had left over from a toilet installation. Get yerself some of this stuff boys, it's coooool. After the stream was sealed up and stopped completely and my family was admiring the glow of my super-hero status, I put the bucket of cement on my shoulder and said to my wife and kids "well, I'm off to the gulf!"
But instead my wife made me put my rain coat back on, go back out, climb the ladder and clean out the gutters. And so it was.
AND NOW FOR THE BOAT RELATED PORTION OF THIS EVENING'S POST:
how many sheets of marine plywood do I need to order to replace the transom wood, floors throughout the boat, cabin bulkheads, helm, side panels and seat tops inside the cabin?
3/4 inch or 1 inch? I'm a big fella so I need a strong floor. Do I need to glass it or does epoxy add enough strength by itself?
If I don't glass it, I'd like to stain the wood then saturate the wood with epoxy to "waterproof" it. But I wonder if the epoxy will stick to stained wood? I have this cool idea where I lay a map of Lake Superior under the epoxy on the "dash board" behind the windshield right in the center above the door.
Pugetsound
A wife with a sense of what my man wants. Better mark keeper on that one. LOL
Bwana Don
Here is what I plan for mine; Good marine plywood, then porch paint (EZmobee's advice). After a marine vinyl, the bumpy kind (to be determined).
Yea, epoxy and glass are great but, price it out. $$$. My friggin dashboard cost $100.00 to epoxy and varnish, epoxy quart $35.00, epoxy hardener $35.00, spar varnish $30.00.:eek: Looks great on the mahogany, but screw the floor. Porch paint it is, thanks EZ.
If I need to replace my floor in 25 years then I'll do it. I don't think the factory glassed in the floors anyway.
My .02 cents Paparoof. One of the benefits of this forum is mulling amongst friends. Mulling IS half the fun.
Map sounds way cool. Lake St, Clair on the floor of my boat hmm........
Good luck~Don
ts
hmmm indeed....
today my thoughts are occupied by buying this motor and dropping it in - as is. Assuming that works out, run the boat for the summer, get used to it, fiddle with the interior. I'll keep the current motor for parts, and think about getting the head, manifold and block cleaned up and rebuilt one at a time, because each one by itself would bolt right onto this new motor, should I have a problem with it. Then once all the parts are rebuilt (maybe as much as a year or two down the road) then do another motor swap and put the original back in.
This is fun to mull over.
I know I'm a little late to this posting party, but it sounds like you are getting the hang of this old boat thing papa! Good luck tuesday!
Cheers!
TS
paparoof
Well got nothing done directly to the boat this weekend, but I made some real progress today.
Picked up a 1 ton chain hoist and load leveler and all appropriate straps.
Also got myself a chain saw and made a path to the boat's new home.
Here's the before picture:
Here's after taking the tree down and cleaning up:
Made some stepping stones outta the trunk:
Challenged the boy to stack the sections back together, in correct order. Took him about 4 minutes.
G'night!
Bwana Don
Lord of the rings.
Looks like ample space to store the big rig.
paparoof
okay I'm going to look at that motor tomorrow - link me to the best tutorial about how to tie down a motor in the back of a trailer safely! I gotz lotsa ratchet straps, but what should the motor sit on?
paparoof
took another look at the pictures in the ad and you can see the feet. looks like it'll sit square on the floor of the trailer if there's enough clearance for the oil pan - that's what I can't quite make out in those pictures.
Do y'all know?
Bwana Don
I like a pallet to strap her down with. I've used an old truck tire to sit a motor into before too. I highly recommend the pallet.
Strap her down on the pallet first. Then strap the pallet in the trailer. Use twice as many ratchet tie-downs as you think you'll need. No sudden stops, no Nascar starts. Steady as she goes Grandma.
Wow, looks pretty. I think you did good. The Islander should like her new heart. Solid compression numbers, nice.
Kainon
It's already on a pallet.. strap to that, front, back and corner to corner.. may need a 2x4 at the back & front under the flywheel shield and front mount.
paparoof
look what followed me home!
I got to see it run and warm up and check the oil and everything looks and sounds really, really good.
Pugetsound
I bet you are grinnin from er to ear. Great choice.
ts
Whoo Hoo!!! Way to go paparoof!
:D
TS
ezmobee
That's great. I think that was a good route to take.
