jaymillikan
Thread starter- Joined
- Jan 10, 2009
- 2
Hey all....
I just recently purchased a 1985 Bayliner with a Force 85 hp on the back. It hasn't run in two years, and the boat's shot. I basically bought it for the motor. It cranked slowly when I looked at it (low battery, no doubt) and when I got it home and removed the spark plugs it turned freely. I'm waiting for my compression tester to be returned to me so I can take some readings, but for $200 I couldn't go wrong. I'm looking for any advice to help make this go as easily as it can. My goal is to get it up and running ASAP because I have another hull to put it on. I'm figuring I should take the carbs apart and clean them first, then worry about trying to start it. I did notice the spark plug wire ends are badly worn, but I don't see a way to replace them without replacing each coil pack. I'll shut up for now and let anyone answer what I've got here so far. Thanks again for your help! Jay
