IGNITION WIRING CRYSLER 75
Scondo
Hi all, I would like to know where the purple wire in my wiring loom goes on the ignition switch ,i have a push in for choke switch,and if i conect it to one of the M positions and measure between the 2 M positions i get a reading of 15v but across my battery terminals i only have 11.5 v.Where am i going wrong.<br />Thanx<br />cloetewilliam@aol.com
eurolarva
Re: IGNITION WIRING CRYSLER 75
The purple wire should go to the rectifier on your motor. If you are reading 15V when it is running that is good. It means the charging system is working. That wire does not go to the ignition key switch. The wire would be connected to a meter on your console like a battery meter in your car.
Scondo
Hi Eurolarva<br />Thanx for that,i do not have a battery meter,can i connect it to the battery.One other thing do i connect the black wire to one of the M posts on my switch.
eurolarva
My manual says white to the M leg on switch. One of the M legs should be empty. Black is a ground. The reason the black goes in the harness it to get a ground to the console. My guess is that the rectifier is already hooked up to the battery somehow. You can test this by hooking a Volt meter on DC across the battery. Start motor and voltage should increase. I am pretty sure that purple wire is there for a meter.<br /><br />What problems are you having with the motor?
Scondo
Hi EUROLARVA<br />Thanx for that ,the engine seems to be running fine ,i just would like to make sure it is charging.I have disconected the purple wire from switch as well as the black,this means i now have nothing on both the M posts,as it is the engine starts fine and swittches off fine,when i put a Multi meter across my battery the volts go up ever so slow.one thing the motor does do every now and thenl,when i crank it to start it will back fire,then crank again and it will start.<br />Thanx again
eurolarva
That year of chrysler can have one of three types of ignition systems on it. My manual says a white wire goes to one of the M terminals on the switch but can go to the rectifier or the cd unit or the distributer. My guess is it is a kill switch for the motor. Another system shows the key switch has only one M and it is not connected to anything and the white wire is connected to the I position on the switch.<br /><br />The back fire you are getting could be a lean or rich condition in one of your cylinders. Have you ever decarbed this motor before? You might want to give that a try and see if it fixes anything. If not I would get a manual and do the carb sync and adjustments. You may just need to fine tune the carbs.
Scondo
Hi again<br />I have ordered a service manual on CD rom .i will do the settings when is arrives.I will have a go at the switch etc in a few days as i am out of town for a day or two,Thanx very much for your help and prompt replies.<br />Regards <br />Will
Scondo
Hi Eurolarva<br />I received the CD Rom Manual and the wiring diagrams are there and have done the wiring up and will test it out this weekend.<br />I do have another problem for you please.a mariner 60 i think about 1990 3 cylinder,at start up it riuns rough as if it is on 2 cylinders aftger it warms up after 5-10 Mins it seems to clear and is fine for the rest of the day,and the samre the next day,any suggestions,as well the tell tail water is to hot top keep your hand there but is pumping ,i replaced the impeller and it has helped a little but water still hot ??
eurolarva
Might have better luck posting this in the mercury mariner forum. I have read similar posts over there concerning this problem. I believe it was a defective coil that dont work well at low temps. After motor warms up the stator (pretty sure it was stator) starts working. Good luck
Scondo
Thanx Eurolarva<br />Will look on the MAriner Form
