hope2cwater
Thread starter- Joined
- Jul 20, 2008
- 7
I got my 55hp chrysler running and it sounds good and smooth. There is no wiring to the engine so I just ran a wire on a toggle switch from 12 volts too my ignition. My question is do I need to have a resistor in the circuit to cut the voltage down so the points don't burn out or will it be ok with 12 volts all the time?
Second question is how do I know when the thermostat opens or how do I tell if it is stuck; either shut or open?
BTW it is a 1967 55hp w/alt. model #55771 Thanks
