Hunter88310
Thread starter- Joined
- Dec 6, 2014
- 8
Hi all new post for me, have seen and read others and still I have not yet chased down my problem. I bought a project boat with a Johnson GT200 model j200stlens, and it has no spark. I started by checking my battery then key switch and stop switch. I then unplugged the black with yellow wire at the power pack and still no fire, reconnected the black/yellow and disconnected the 2 yellow wires from the stator to the rectifier, still no fire, reconnected those. Next I disconnected the 2 pin amphenol connectors one at a time and measured the resistance between the 2 wires in the plug going to the stator Brown and brown/yellow. There are 2 of these plugs coming off the stator and going to each side of the power pack. The port side measured 923 ohms, while the starboard measured 932 ohms. Both within spec based on the CDI troubleshooting page. I then unplugged the large red plug on the port side and used a remote starter to crank the motor, still no fire. I do not have a meter that reads peak voltage to get a DVA reading, or if my meter will do it, I do not know that procedure. My meter is a radio shack meter I paid about $60 cat # 22-172. It has a clamp meter function that I used to measure the amps my well was pulling when troubleshooting a well pump. So if I can get DVA readings with it and someone knows how please let me know. Next I moved on to testing the resistance in my time base plugs. The test procedure from CDI stated that from the white wire test to all the others and they should be about the same, and be between 1M to 5M ohms. From my white wire to the purple in the same plug I was open, From the White to the green in the same plug I was open, White to Blue was 109.6K ohms. Based on these measurements I believed the timer base was bad. I found a used one on EBAY from a marine shop. It is allegedly tested to be good before being sold. I received it, and started my motor disassembly to start the replacement. the first thing I noticed when I removed the flywheel was how shallow or short my flywheel key is. It has nice square shoulders but I was surprised that it does not protrude very far above the crank shaft. I am used to automotive harmonic balancers ect and they protrude much farther. there is no sign that it has slipped or spun that I can tell, but are the keys usually so short on outboards? When I removed the timer base that was on my motor, I noticed there is no brass bushing, indeed no metal at all on the timer base I removed. It is part #763775 and I show it is a replacement for the obsolete 585586. The used one I found and purchased is an original 584586. So once I got the timer base removed I put it on the bench and got out the multi-meter. I set it for ohms and compared the readings on both timing bases. My original timer base I just removed shows these resistances when measured to the white wire. ALL are open except from the White to the Black/White which shows 222 ohms. When I did the same measurements on the new (allegedly good used) timer base I just purchased I get the same. This has me concerned so before I mount this timer base and bolt it all back up I think I will remove and try to bench test the stator, power pack and rectifier. any other guidance is appreciated.
