I have avery similair problem, only with a 6 wire switch. The old switch works great ,problem is the treads for the coller nut broke off anyway. The old terminals are labeled.
B,M,A,M,S,C
I'm going to assume that the C-is the choke as the switch was a push to choke, and the rest are the same as what Silvertip has described. The problem I have is that the switch I bought A (Sierra MP41000 Ignition Switch) also a push to choke is labels with has
I,S,M,B,M,C
The box labels the terminals as
M=Magento
C=Choke
I=Ignition
S=Solenoid
M=Ground
B=Battery +
I'm confused as to what happened to A, and were did I come from. I think all others are the same. The terminals are in different locations. So are I and A really one and the same or do I have the wrong switch.
B,M,A,M,S,C
I,S,M,B,M,C
M=Magento
C=Choke
I=Ignition
S=Solenoid
M=Ground
B=Battery +
