Ignition switch replacement
Realgun
I have a 1988 85 Hp Force 856X8a.<br />I am replacing just about everything and the switch is included in that also. The only issue is that on the switch is 2 M's. I know from the diagram 1 is + the other is ground.<br />
<br />On the engine is a label that states the color is white and blue. I have both at the old switch. Also there is a white wire that goes to the kill switch too on both of these.<br />Problem is there is no indication of + or - .<br />I hooked up a wire to ground at the battery, battery was not installed, The with was 0 ohms and the blue was 1 meg ohm. I am going to assume the 0 ohm which is white is the correct ground.<br /><br />Any comments as to am I right or will I blow up something?<br /><br />BTW the switch did turn the engine and click the selanoid so I thing I got that correct at least.
roscoe
Re: Ignition switch replacement
I believe that the 2 "m" terminals are interchangable, and acts as a kill switch when the key is in the off position. They just connect to each other when the key is off. My manuals confirm this.
Jcrain
Roscoe is right. The magneto reqires a path to ground to kill the spark. These switches just connect one "M" to your magneto, the other to a ground. On your diagram, you are correct, so wire it up the way the diagram shows.
Realgun
Thanks guys. BTW that switch came from iBoats along with a few other electical items.<br />The diagram is a picture of a printout of the webpage technical section at Seadog. :)
