1979 260 mercruiser Chevy 350 block:
We were having problems when we were running the boat for a while and then it would stall and not start back up or fire sputter and die. Started right up and ran smooth until hot. Marina mataince guy suggested checking how hot the coil got, ran till stalled and could barely touch the coil for a few seconds. Was told resistor could be bad and to replace coil with a coil w/ internal resistor since couldn't find the inline resistor. Well rushing to get it done before work and hooked the black wire going to the side of the distributor to the positive side instead of negative. Tried to start boat and blew breaker and 90 amp fuse on the starter cylinoid. RePlaced fuse, points, condenser. No start. Getting 12v on power line to coil 7v coining out of coil to distributor. Ignition on, move points by hand, no spark at points. Not much spark coming out of coil if any when tower wire is grownded to engine block. It used to always start right up before mishap... Don't know what to do next... Oh, pulled tack wire in case of short... Among other things...
