Ignition problem on 1985 Johnson 90 VRO
Bdubs68
I'm bringing an 1981 starcraft back from the dead, it's got an 85 Johnson 90 v4 vro. Today I was tackling one of the many gremlins, I had a warning buzzer staying on constantly when I turned the key to on position. I've got OMC controls. I found the problem to be the two purple wires and the tan wire going to the warning buzzer where pinched together in the control housing so tight that the copper wires were showing from the insulation and touching each other. I pulled the two connectors off the terminals on the buzzer, and taped up the wires, then ground a little bit of the control housing to make extra clearance so they won't get pinched again. This fixed my buzzer problem, but while messing with it I accidently touched the connector with the two purple wires to ground and I seen it spark. After that I've got nothing.. No click, no engine crank, nothing.. could I have ruined something when I grounded those wires?
Silvertip
Honorary Supreme Mariner
Replace the fuse under the engine cover. Probably a 20A.
Bdubs68
I have pictures to go with this but it looks like I may not be able to post them as a new member.
Bdubs68
I thought about a fuse but I looked around the engine and can't find them. If it sounds like I'm inexperienced it's because I am. I see where all the wires go to a block on starboard side but I don't see fuses.
JRegier
The fuse holder is a little round guy right by the motor end of the red electrical plug under the cowl
Bdubs68
Alright, I found it! The fuse does appear blown. Thanks for your help JRegier and 175se!
