Ignition Module
Sam Munn
I have a 1998 Evinrude, 9.9hp 4 stroke, high thrust. My mechanic tells me some parts are no longer available for that engine. I need an ignition module, part #0586136. Can anyone help me?
Daviet
Re: Ignition Module
You're welcome, if your mechanic has anymore problems, come on back and ask.
Sam Munn
Re: Ignition Module
Well actually, it now appears the ignition module is OK. He is leaning toward the coil (which seem to be scarce to unavailable???????) or the stator. I tried that MARINEENGINE.COM site for the coil. They listed it as unavailable.
From what the mechanic is telling me, parts for this engine may be scarce, if available at all. I am considering getting it repaired if possible, then selling it to get something else. This time around I am leaning toward a 6hp. I would entertain suggestions as to what brands and models might be good. Bear in mind I probably won't be buying anything brand new.
tx1961whaler
Re: Ignition Module
Some of the parts for that motor are scarce. Your mechanic seems to be guessing. He should be able to use a DVA to determine what is wrong in the ignition.
Yes, that dual coil is unavailable. A 583740 coil can be "rigged" to work using 512256/512478 connectors.
You do have a Model HE10FELECA ??
Chris1956
Re: Ignition Module
I had always thought that replacement electrical and fuel system parts were required to be avail for 20 years after manufacture. Obviously, if a motor is popular, manufacturers and aftermarket places will have those parts long after that deadline. i.e. coils and carb kits for fifties Evinrude Big Twins.
boobie
Re: Ignition Module
You have to remember that BRP now owns the old OMC. I've seen a lot of parts that are now NLA which in the old OMC days you rarely seen that. O' well.
woody66912
Re: Ignition Module
Yep boobie, have a sx drive in the shop now with a smoked upper. Would be able to make a fast turn around and maybe a few extra bucks, be lucky to break even. Have to out source parts.
boobie
Re: Ignition Module
Woody, do you ever check out the dlr port message board ?? Interesting.
woody66912
Re: Ignition Module
Yes I do, but we have a dealer within 30 miles of us, that I used to work at that gives us somewhat of a break on parts. It's just getting tougher dealing with the OMC brand. Oh well.
