tinytanic1
Thread starter- Joined
- Aug 7, 2007
- 13
While my 16ft runabout is running the ignition coil gets so hot you can't even touch it. Then if you shut off the engine, it won't start again. I've replace coil, distributor cap, points, plug wires, and the external resistor wire that connects to positive side of coil. Sometimes, I have a full 12 volts at the coil, other times I only have 6 volts. I should have a reduced voltage at coil due to resistor wire I think? This is 1977 Mercruiser 120hp (2.5L) with 4 cylinders. HELP! I've run out of ideas!
