bang4dabuck
Thread starter- Joined
- May 24, 2009
- 296
TRIM - In the manual, diagram shows a connection, circle with a S, G and I. I'm thinking that is a gauge. If so I don't think I need it (small boat - no room on console). Is that a trim gauge and if so can I furget aboud it ? Wires are White/Tan, Black/Gold and Purple.
TRIM - White/Blue wire broke near plug at engine. It doesn't look like it was done on purpose but it looks like it was like that for a while. Just solder it ?
IGNITION - rectangular box 2.5" x 2" x 1" (all approx) two wires only. One black and one gray. Black connects to WARNING HORN. What is this box and where does the gray wire connect to ?
WARNING HORN - Circular approx 2" diameter and about 3/4" thick. Has following numbers/letters. MX 2 W27. Has a brown, 2 purple wires and the black to the circuit breaker(?). Is this horn for temp or VRO ? Do I need to update this horn? I plan on disconnecting the VRO.
I got a Evinrude/Johnson Official manual. It's pretty thin. Would a SELOC cut down on my questions ?
