I am new to the board so bare with me. I have a 1975 Johnson 70 hp outboard, that has been running fine for about a year now since I purchased it. Yesterday morning, come to start it up, no fire on all three plugs. Started troubleshooting the problem, removed the black and yellow wire from the pack, to check key switch, still no spark. Did sensor coil resistance check according to manual, within
range. Charge coil checks ok. Started to suppect the power pack was back. However, after a few hours of fooling around with wires, to my surprise I had fire on all three plugs. Installed plugs, and engine fired right up. Ran it for 10-15 minutes in driveway with water to lowerunit, running great. This morning come to start engine, no fire again. Pulled red plug apart, did continuity test on conductors from harness, all okay. My question is could a conductor be broken inside the insulation or could the conductor fail under load? Any ideas please let me know? Thanxs guys
