if u love a challenge( help me)
panhandleiceman
i recently had a propblem with a beep...beep...beep noise coming from the controls.i took it to the shop were i was told i had a faulty hot horn.it was fixed but now the motor runs as if it has a rev limiter. it will idle fine but when u give it the gas it will vroom...vroom...vroom over and over but it idles fine.it seems life i can turn it off and restart it and it work fine.any advice will be greatl appreciated PS the vro is by passed
rodbolt
Re: if u love a challenge( help me)
hello<br /> really need more information. if the motor has slow then momentarily disconnect the tan wires at the temp sensors on the head to see if SLOW is triggerd. had some problems with old sensors that would trigger the pack and not the horn. good luck and keep us posted
panhandleiceman
i have undone the wires but still having the same peoblem. what info do you need.<br /><br />thanks so much for your quick responce
rodbolt
model#, seriel#, and a better description of the problem please :) :)
