idles great but falls when coming up on plane
nitro196
have a 19ft nitro with a mercury 150 boat sat for about a year year and a half took to the lake and it idles fine but when you go to get up on plane it doesnt want to get up out of the hole like it use to the motor doesnt seem to bogg down or anything like that it just doesnt open up like it use to and the boat was winterized prior to it sitting Thanks
studlymandingo
Re: idles great but falls when coming up on plane
Do you have fresh gas in the boat?
Did fuel sit in the carbs over the time it was stored?​
nitro196
there may have been some old gas in the bottoms of the tanks and possibly in the carbs
nitro196
the tanks were empty i put new gas in when i took it to the lake
branman1971
You said, "the motor doesnt seem to bogg down or anything like that"
So the motor revs up normally? If so, sounds like a problem between the drive train and the prop. Like when my boat's prop gets seaweed wrapped around it, and the motor spools up but doesn't really get after it, just gets bogged down.
j442w30
Is the throttle response lazy? I'd suspect the carburetors need rebuilding if it sat for that amount of time? Did you take a look at the spark plugs? If it was winterized prior to storage then the fogging oil that was burned off when you started it up could have fouled the plugs. I'd have a look at the plugs, otherwise I would suspect the carbs.
studlymandingo
I would definitely get after the carbs first. Get a gasket set and tear them down and give a good thorough cleaning.​
licketdsplit756
johnson makes a fuel additive that may help in cleaning the carbs out. if winterized i dont suspect you may have to go thru the trouble of rebuilding the carbs.just something else ya might want to consider. my thoughts are always start small then work up.seen many$ spent on parts folks didnt even need. you go that route and your liable to spend alot of$ when you could have used that money for a new fish finder.???
