Re: idle speed
The idle adjustment screw is #51 in the diagram
HERE
BUT if you are saying it runs with choke but not without then perhaps you should be looking at the idle mixture adjustment on the carb. (See Joe Reeves' instructions for carb needle adjustment on the Engine FAQs board.) If the carb needle cannot be adjusted to a point close to the basic setting then the carb probably needs cleaning.
