idle speed switch
BAO
Hey guys thankx for all your help on my other post. Now for new question. The idle speed switch on my 1988 dt65 does not seem to do anything should I be looking to buy new switch or is there something else to this?
gsyfishy
Re: idle speed switch
Are you having idle issuse? Such as it wont idle? I have a 1988 dt-150ss that the switch will not bump up rpm's the usual 50 rpm as per the manual. I've tweaked the idle screws to get the proper 600-700 rpms that are required to idle, but I have'nt seen any tests on this switch to verify that it's bad. So I just deal with it, but it would be nice to be able to test it without spending money needlessly.
BAO
ya when I idle down to shift gears it sometimes stalls guess I wiil have to adjust idle the old fashion way
gsyfishy
I only re-adjusted the pilot(idle) jets, be careful messing with the carb settings too much, as you can make the problem worse.
