IDLE MIXTURE
bulldogs
I HAVE A 120 FORCE AND MY IDLE MIXTURE IS SET AT 2 FULL TURN. IS THAT TO MUCH? IAM NEW AT BOATING AND I HEAR ABOUT RICH AND LEAN WHAT IS RICH AND LEAN? WOULD MY BE SET TO RICH OR LEAN?<br /> :confused:
sony2001
Re: IDLE MIXTURE
Its probably a little too rich. But if it works leave it.
fone_man
Re: IDLE MIXTURE
RICH = MORE fuel delivered to combustion chamber <br /><br />LEAN = LESS fuel delivered to combustion chamber<br /><br /><br />LEAN Mixture will cause just as many problems as a RICH Mixture!!!<br /><br />The idle screw adjusts this mixture of air to fuel ratio.<br /><br />Screwing the idle mixture screw IN will decrease fuel to air ratio & OUT will result in the opposite.<br /><br />If you do not know what you are doing this could result in poor idle, engine shutting down on you, etc... better left to someone with the expertise/knowledge of the settings.<br /><br />Hope this answered your question......<br /><br /><br /> :cool:
