Idle good sometimes
Ratvon
My four stroke 2005johnson 25 hp sometimes idles great then when I think it's ok it wont idle at all. It's got a new fuel filter it sounds like a fuel supply problem to me and it has been sitting for four months. I had the carbs rebuilt two years ago are there any threads to check the fuel pump?
gm280
Well :welcome: aboard Ratvon. Glad you could join us here on iboats...
So it has been two years since the carbs have been cleaned and reworked. I think I would buy another carb kit and remove the carb and disassembly it and thoroughly clean it and install new parts and try that. The little pin size holes in the carbs doesn't take much to plug up causing problems. Amd that is especially true when they sit and not used for some time. So clean the carb and check the fuel to make certain the fuel pump is doing it's job as well. I think that will help with your problem.... JMHO!
Ratvon
How do you check the fuel pump with an inline gauge? if so what kind of pressure should it have ? Ran it today and it was fine I think if it was one of the carbs with a jet or passage way plugged it would do it all the time. Worked on lots of car and motor cycle engines but no outboards thanks for the help
Ratvon
I got lucky it was just bad gas...... I get that a lot lately
