Hi,
I’ve done a ton of research, read the manual, and I’m still slightly confused. I set the idle timing and max timing by following the manual and set it to spec but my idle is still around 1400 rpm. The manual and forums say to adjust the screws on the carbs, but when I do that I don’t notice anything substantial. I had the screws set to 1 1/4 out, moved them to 1 1/2 out. Should the idle increase or decrease as they are turned outwards?
