identifying controls??? help
poor man
Hi yall its been a long time but im back on the water again..(well almost lol)
i bought a boat (no motor) the controls look like a mercury but i never seen a plug like this.. can you tell me about it? what motors will it fit? the controls are mounted inside the walls of the boat and all that is showing is the "handle" the wires look new and cables look new too. so id like to see what year motors would work and if a marener motor would use the same plug??? thanks again....
oldman570
Re: identifying controls??? help
The plug pictured is one for a Commander control that mates to a late 1980's Mercury motor with T/T. It is the same one I have on a 1987 70HP Merc. JMO
Oldman570
poor man
thanks, most of the merks i see have a sideways round plug on them, i dont see any with a straight plug like this sticking out of them :( i was hoping to ffind something to fit this control just so i didnt have to take it out, i like the looks of this control set up.. thanks
That looks like the one on my '93 Merc
poor man
thanks guys does a merk plug fit a mariner >? and will my plug fit into the side of a merk motor that has the 90* round plug?? thanks
poor man
is there a way to make the straight plug i have fit the 90* plug i see on most merks? thanks
oldman570
It could be done buy making a adapter to go from the newer commander control to the old Merc motor plugin style. Probably more trouble than what it's worth. Upgrading to a newer motor is best and can not hurt the value of the boating setup. The newer style plug you show is connected inside the motor cowling and the lose wires shown are for the tilt/trim of the motor. You can search around and might find a adapter that is already premade for your motor or get a newer motor cable harness plug and splice it on your existing motor harness also.
Oldman570JMO
poor man
thanks Oldman, do you know what year they started using the "new" plugs???? thanks again
Those male plugs on the starboard side of the Merc's are from the early 80's and older. Depending on what kind of ignition you have, maybe you could buy a newer engine harness with the round plug. Alternatively, the wires will be compatible, so they could be grafted.
