identify year model 25 hp johnson
terencew
just got 25hp johnson found number on block welsh plug g2955538 am trying to id year model
oldcatamount
Re: identify year model 25 hp johnson
That is possibly a serial number there. Is there a small aluminum tag on the transom clamp with a model number on it? I just looked through my book and I can't find that number anywhere.
terencew
havenot found tag on leg is no 18805501b01 on transom mount but dont think that is number i need thanks for hint:) also am in australia would that make difference:)
oldcatamount
can you post some pictures of the motor? That may help us.
Bdoyle0075
Hey I had the same problem with my Evinrude 130. I took the freeze plug number, called Evinrude and they gave me the year and model on the spot. Give it a try.
ezeke
It's most likely model year 1991. Call BRP/Evinrude - they can tell you the model number by your serial number.
terencew
no not yet local guy not that cooperative
Bdoyle0075
I did not even fool around with the local dealer, I called Evinrude direct at
(847) 689-7090. Very helpful, bet I was not on the phone for more then 5 Min.
gazza2007au
google hunts marine there the stockist for evinrude/johnson parts plus other models they can tell u the model from the serial number
terencew
thanks tried ringing hunts marine they couldnt or wouldnt
tried brp they dont return ph calls or straight out wont answer phone
have found that motor is between 1990 and 1995 through searching part numbers. now all i need do is find wiring diagram to work out whether i can charge a battery from motor or not thanks all
