Identify my outdrive...
DrEvil
I jsut got this boat as a project. It is a 1969 Wellcraft with a 4,3 and an OMC outdrive. I just replaced the transom seal, and I want to upgrade my steering from cables and pulleys to a Teleflex system.
I need to identify the outdrive so I can get the necessary hardware to convert the steering. If anyone knows what parts I need it will help more as I am new to boating.
TIA
EricR
Re: Identify my outdrive...
That is not a 4.3, in case someone told you that was a GM engine. That is a smallblock Ford, likely a 302. Definitely an early OMC electric shift stringer drive.
Bt Doctur
800type drive? "cables and pullys" was this a "tru-coarse steering "?
motor appears to be ford but i never saw a ford with a canted dist. Buick maybe? Can you take a closer/better pic of the motor.
bomar76
That is a Buick engine....note the location of the oil filter.
72IMPAZTEC
UMMMMMMMMMMMMMM not sure exactly what it is....
BUT it is not a FORD V-8.
I don't think it is a FORD anything.
I think it is a GM V-6, likely a Buick. 231.
EricR
Yer right, it's not a Ford. Thought I saw four plug wires going over the valve cover. Too many Bud Lights.
DrEvil
It IS a GM engine. Of course all the numbers are at work... Ill post them tomorrow.
The engine is a 4.3 V6 with a 2BBL Rochester Carb. All parts are labeled GM, and I think it may possibly be a 231... I need to get the casting numbers from the block. DOes the 231 have the same firing order as the 4.3? I wonder...
The outdrive is labeled " Outboard Marine"
All tags are painted over or missing. Once I find out What it is I need to track down an owners manual.
I do have the electric shift.
Haut Medoc
Oh the horror!.......:eek:
Buick is GM......
I hope you didn't pay too much.....
You have your work cut out for you & thensome....
There is still time to get out & save your money for something worthwhile.....;)​
Rob454
LOL thats a Buick motor. Reason I know is i jsut pulled one out of a boat I was given and sold it for 100$. the outdrive is a OMC electric shift. It had that too. Sold it for 150$.
Rob
Ayuh,......... Sorry to hear that,.......
Part it Out,+ sell the pieces on ebay,...........
Then take the Cash,+ buy a Real Boat.....................;)
Dakota47
bondo is correct. sell it. not worth your time.
