Identification of Johnson outboard
David Golding
Greetings. I have just purchased a 2nd hand Johnson 9.9HP outboard. Can someone please help me identify the year and specifications. What ratio petrol/oil mix?<br /><br />Model Number 10424G<br />Serial Number A101271<br /><br />Manufactured in Australia<br /><br />Many thanks,<br /><br />David
Bear
Re: Identification of Johnson outboard
Hi David!<br />10424 Evinrude 1974 9.9HP<br />The mix is 50 to 1. This means 50 parts of unleaded gas to 1 part of TWC-2 or 3 outboard motor oil. <br /><br />Check this, print and save:<br /> All you need to know <br /><br /> :D
Bear
Evinrude and Johnson are idendical exept name and colour.<br />Johnson model numbers 1974:<br />10E74-10EL74 or 10R74-10RL74 <br />So don't be :confused: <br /><br /> ;)
vscalais
Greetings again, and thanks Bear member #829 for the quick and very helpful response.<br /><br />Someone told me that I can upgrade this motor to 15HP by simply changing the carby! This sounds too good to be true. Have you ever heard of this?<br /><br />Best regards,<br /><br />David
the machinist
Thanks Bear, for refering my article on the 9.9/15 OMC's that I did as webmaster for PSA on to those in need. <br /><br />If you have not looked at it lately, I have updated it with more info & have started on the lower unit rebuild also.
vscalais
Thanks Machinist for keeping this site open and available. It's been a great help.<br /><br />One quick question? I want to upgrade to the 15HP carby, and enjoy the extra power. What carby part number should I be looking for?<br /><br />In replying to this post, could you also reply to my personal email address david_golding@optusnet.com.au<br /><br />Kind regards,<br /><br />David (Scouts)
