beckoning
- Dec 15, 2010
- 182
My boat sits on a hoist out of the water when not in use. The back of the boat sits over 8' of water. I cannot reach the bilge plug to remove it to drain the boat after a heavy rain. On my old boat, I could remove the plug at all times in the hoist so heavy rains would just run out, then replace the plug when heading out. On the new boat, I can't reach plug to remove and re-install each time I go out. I will install an automatic bilge pump, but want a foolproof backup. Ping pong balls and duckbill flappers don't interest me. I have a cable operated bilge plug that I could install, but it seems too untrustworthy.
How about this idea? I could securely install a tube in the drain hole, then using a SS hoseclamp, connect a 3' piece of quality flexible hose to the tube and put a removable plug in the end of the hose. Whenever the boat is in the hoist, I remove the plug from the end of the hose, and drop the hose in the water allowing the boat to drain. When heading out to fish in Lake Michigan, I would pull a cord connected to the end of the flexible tubing and bring it back up into the transom and reinstall the plug. Wouldn't that work?
