Re: Idea for automatic boat lift on a budget
I just tried this. I went to a junk yard and bought a starter and flywheel off a 1987 cadallac (both cost $41). I mounted the flywheel on the back of the crank wheel between the big crank wheel and the Gear Box. I mounted the starter on a platform extending from the gear box. It was (is) a great idea. My thought was I can use the lift manually to lower the boat, and if I have to crank it manually I could do that too (since the throughout gear on the starter only pops out when energized). The problem I had was getting the starter and the fly wheel to engage. They have to be lined up perfectly and I could maintain the tight tolerances needed. Someone with a little more skill, and patience could probably get this concept to work.
Let me know if anyone tries it - I think it has merit.
Hi you should just get a 2000 or 3000 lbs atv winch it has everything that you need and they work from a 12 volt battery it is simple it is strong and it is made for pulling or lifting heavy loads. Good luck.
