ID Tilt/Trim assembly by look?
ashedd
I need a trim/tilt assembly for my '83 115 evinrude, I can find several part numbers but I'm not sure what I need. I see several on ebay that look exactly like the unit I have, is this good enough? As long as it looks exactly same will it work? I see about three different style of units on ebay.
Thanks
emdsapmgr
These units do have a similar appearance. The big thing for you to watch out for, is the motor. Early trim units had a three wire motor. The factory change over to the two wire system occurred mid year in 1981. OMC made both in 1981. Yours is considered a "later/newer style" model, with a two-wire motor. You are best to replace your unit in kind with a 2-wire motor setup so that it is compatible with your existing electrical trim relay box.
willamettejeff
Rare to need to replace the whole unit. Are you sure you don't just need a new motor? Or perhaps a relay or switch? What is or isn't happening with yours?
