Re: I want my exhaust louder for a low price
Howdy,
I had those thru-hulls on mine too. In fact I had the Corsa Capts Call system when I had the 460 King Cobra installed.
I thought about hooking them up after I pulled the Cobra out and decided against it.
They didn't do anything for performance and every time I switched them to "thru-hull" everybody in the boat would yell "Turn it off turn it off turn it off!!!"
So I left them off most of the time. I didn't install them with the 454. They're sitting in a box now. I guess I'll "ebay" them along with all the other Wunderful king Kobra stuff.....
Now this thing will now blow an OMC powered Liberator right out of the water! Thru hull or not! (one of these days I'm going to swap out the 454 for a 502!)
By the way, you can see the water line on mine. That's where it is with a "big block" in it. (actually it's even lower than that too.....since the drive is not completely submerged The 454 might be only a few lbs lighter than a 460 ...but the Bravo III is MUCH heavier than a Qing Qobra!!). If yours are lower than that you may have them too low. be careful of reversion if one of your flaps sticks open or breaks off...
