45Auto
- May 31, 2002
- 2,842
Re: I try and get away from ramps ASAP but . . .
Gas fumes are heavier than air. They sink to the bottom of the hull. All the vent holes in the world won't do you any good (unless they were in the bottom of the boat - but then you have to worry about that wet stuff coming in .....)
No need to pipe it from the bow. At anything above idle speed you get plenty of air flow from vents anywhere around the engine.
The purpose of the blower is to provide engine compartment ventilation when the boat is standing still or moving so slowly that there is no air movement through the vents.
I'm curious why they don't put vent holes to eliminate the problem?
I'm thinking intake vents high above the water line at the bow that piped into the bilge and discharge vents at the stern?
