I think I messed up bad.....
churnee
So I was having a hard time getting spark from my '75 40555c 40hp Evinrude, so I attempted to pull the flywheel..... before I looked on here to pull it the CORRECT way. I used a 3 jaw puller and was stupid enough to break part of the flywheel off. I know, I shouldn't have used that but I did and now I feel like I am learning the hard way. DSCN9806-2.jpg
Is there a way to fix the piece that broke? The part is listed as obsolete on BRP's website. I am assuming that it is a balanced flywheel and having it welded would mean that I would have to have it rebalanced. JB Weld? I am kicking myself so hard right now..........
Thanks for any help.
churnee
I seen that one on there but not sure that it would fit my motor. Different part numbers. Nothing cross references my part number. It looks the same but if there is a small difference it could probably mess things up pretty quick spinning at that speed. I am pretty new to outboards(obviously) so I figure I would consult with you guys here on the board.
Bosunsmate
im cheap, id try and take an equivalent bite out of the opposite side, looks like only the light weight lip thats gone
Faztbullet
Thats the rope groove and it will be fine...I seen worse than this still running
gm280
They still list a new one for $165 dollars on boating sites for that engine. It is the exact same part number as the Johnson flywheel (0581334) as well. So expand your search and I think you can find one. I would be very suspect for any welding effort. The outer edge of that flywheel is spinning extremely fast and if any suspect weld job is tried, it could come apart and a simple fiberglass cowling will certainly not stop it from flying who knows where...dangerous in my opinion. The kinetic energy with that hitting somebody just isn't worth it in my book. So they still list new ones for that year engine. Google search the part number and see what is available... JMHO!
churnee
gm280, that part # is for the manual start, I have the electric start model. 0581345 is the part number that I need. The manual start is missing the gears for the starter to engage on. The kicker is that the electric start flywheel is listed as a $66 part!
Faztbullet, what would be the repercussions of letting it go? I thought about letting it go because it's only 2 grams that is missing. I have the piece that broke off but wasn't sure if it would be that big of a deal to go without.
Bosunsmate, this is an option that I could possibly explore if just leaving it like it is, is going to cause damage.
Thanks guys for all your help!
gm280
I honestly thought the 1A was for the combination flywheel that had both rope capabilities and teeth. Another option is look at some old boat salvage yards and see if you can find one. And if your flywheel seems out of balance running, you could remove an equal amount straight across the flywheel to the opposite side. Just machine off the sharp edges and boat on...
