jrs_diesel
Thread starter- Joined
- Mar 3, 2010
- 552
I am rebuilding my 72 Johnson 6HP. Tonight I got the crankcase seperated, and the crank and pistons out. The crank and connecting rod bearings looks and felt fine.
My upper piston (#1) pushed out just fine, but my lower piston (#2) took a little more force to push out. The lower piston was also scored slightly, but I observed no damage to the cylinder. The cylinder walls are smooth (felt with my finger), no scatches or other visible damage, and I still see the original cross hatching.
I've attached several pictures. The first two are of cylinder #1 (upper), and the last 2 are cylinder #2 (lower).
How do they look and should I hone them? I am replacing the piston rings either way.
