waterinthefuel
Thread starter- Joined
- Nov 15, 2003
- 2,729
I bought an old bass boat and everything on it works good enough except this trolling motor. It has one of those foots that screws to the floor and simply has an on/off switch, a variator in the middle, and a high speed bypass switch. Steering is done with a pole screwed to the trolling motor under the head.
Well, when I got the boat I got it working fine after fiddling with everything and just getting everything moving again. I drag the boat 30 miles to the ramp and now it only goes on high speed bypass. However, if I move the foot around by unscrewing it off the floor, sometimes I can get the variator to work properly. But when it doesn't work, I just hear clicking in the head. I took the top off and the relay is what's clicking, but everything looks fine. No corrosion, loose wires, etc. Same for the switches on the foot. I also did notice that the fwd/reverse switch doesn't work, it only goes in forward. I'll diagnose that later, but right now I'm worried about the variator in the foot. I've never seen one like that. Can someone help me out? Could this be a grounding problem for something? I'm so lost, I've never had a trolling motor like this before.
