I have read the other posts on this topic and have been thinking about this conversion for my 1979 Carver 23' runabout. It's powered by a mercruiser 260 - which I am tired of always working on. I would likely replace the 260 with a 250 outboard, but those suckers are 600 lbs, plus change.
I was thinking that the transom repair and new bracket for that large of an outboard would be strongest when tied into the existing I/O engine stringers, but am not sure how that would work... seems like the stringers support weight applied from above, not cantelevered and attached from behind.
Anyone have any thoughts about conversion of such a large power source?
I understand the basic reluctance - especially since an I/O transom is not built for a large motor to be hanging off the back... Although, it is a very common practice up here where I am (SE Alaska). And, I have access to good aluminum fabrication services as well as folks who can repair fiberglass... sadly, I just don't have access to a good I/O mechanic.
Yes, I know the cost difference is extraordinary. I also know that an I/O engine compartment is just a potential puddle in which your engine will eventually take a bad swim... And dang if changing the starter isn't a serious chore!!! And the engine cover is always in the way when hooking up a big king, or trying to land a big pooner halibut...
Thanks for your thoughts.
