dozer91250
- Mar 6, 2013
- 8
I'm new here and have read a ton of stuff, some I wish I would read sooner (I now have tons of Jiff in both creamy and extra crunchy, not what PB meant. I know that now), but I can't seem to get consistent answers on epoxy based and poly based compatibility.
Correct me if I am wrong, but polyester resins (ie gelcoat) will not adhere properly to epoxy resins. Assuming that statement is correct:
(1) I am perplexed that many of the fillers and fairings are epoxy based. If you use any epoxy based products on the substrate are you then prevented from using any polyester based topcoats?
(I have asked my Orca Guard Gelcoat vendor, Fiberlay (sea, wa) and have received conflicting answers about compatibility, the product tech sheets are woefully inadequate, and the product mfr will not respond to inquiries so the question remains).
(2) If so, is there some sort of a surface sealer or tie coat that you would seal over the epoxy based products to allow the polyester based topcoats to adhere properly?
Thanks,
Thanks,
