I need the part number for oil pressure sensor
Freeman1982
Hello guys please help me, I need the part number for the oil pressure sensor and the right size of the propeller to my boat .
Engine part number attached
Fun Times
Hi, just letting you know that at the moment I’m not seeing any attachments of photos of your engine model…
Can you type out your full engine model as it should help locate the correct oil pressure sending unit and other parts lists for the future.
Fun Times
40869324
A196003
50Gxic-270-R
VP number 3887328
Item number 15,
Bt Doctur
if a "sender" verify the ohms and check if a mercruiser one is the same rating
my be a bit cheaper . check other companies gauges also
Freeman1982
Have you gone here and looked? https://www.volvopentastore.com/
VP number 3887328
Item number 15,
Appreciate your help
