I need help
matt126
I have a 1989 gt200stl the revlimiter is kicking at around 1300 r.p.m. I disconnected the temp. switch & it ran great so I ordered new switches & I still have the problem I think previous owner (s) did electrical work so maybe something is loose or missing. Could I just run it with the temp. switches unplugged any help is appriciated
countvlad
Re: I need help
i wouldn't run the motor without the temp switches unless you have enough money or you don't care about the motor....
do you have an alarm? does the alarm go off when you have the switches plugged in? have you tested the alarm, does it work?
matt126
Re: I need help
The alarm buzzer works but it is not signaling when the revlimiter kicks on. I should explain when I launch the boat it runs fine then I fish or set whith the motor off for an hour or so when I fire it up it shouldn't hot but it will not rev up or plane out
Theoutdoorsman
Re: I need help
Verify that you can you hold your hand on the heads for at least 10 seconds, or more, while the motor is running and while the problem is occuring?
matt126
Re: I need help
I have not felt the heads but the water flow out of the engine is not hot . I will check the heads next time I make it to the lake thanks for the help
matt126
Re: I need help
I ran the motor in the driveway for 45 min. the heads were not hot the exuast water was warm so I belive the cooling system is working
