Re: I need help with a 9.9 evinrude
Stream_fisherKY<br /><br />Now I won´t be throwing more ideas at you, before you get started. I was wrong, the fuel pump is on left side of your engine, not right. You can check the piston rings by mesuring compression. If compression is 90 or more on both, rings will be O.K. Maybe your engine needs decarb, i understand your gasoline isnt as good as ours.<br /><br />Maintenance ? The impeller should be changed every second year. The lower unit oil, with a good marinegrade oil, at the end of each season. The gear oil is designed to absorb a little water if it gets in, therefore fresh oil before winther. Lubricate all links under hood every year, when you runn motor last time of season, spray oil in motors airintake, while running. Flush cooling system with water mixed with preservation oil at end of season, and run engine till carb is emty. Start new season with fresh plugs and fuel. Good luck, write me if i can be of any help
