Stream_fisherKY
- Jan 5, 2002
- 62
I have spent hours reading on iboats.com in search of an answer to a problem that <br />I am having with an Evinrude 9.9. So far i haven't found any sure answers so i need some help. I think the engine is a 76 model (either 76 or 74). I just bought the engine last year and since then i have had the carb rebuilt and changed both points and<br />condensors. I was told that the engine had been sitting for nearly three years when i purchased it. Last season i ran the boat several times and i had a recurring problem. The boat will start and run great, that is as long as the plugs can stay good in it. I commonly kill at least 4-5 plugs a day<br />in my little 2 cyl engine. I have tried to pattern it lately and i have noticed that it most often occurs in the lower cylinder. I will be running the engine full power and then you can feel, and hear, it starting to have problems. It will start missing and gradually lose power until it finally<br />begins running on only one cylinder. I know this to be a fact because i have stopped the engine and pulled the plug wires one at a time to see which one is good. It will start and run with just the top plug connected when<br />this problem occurs. I can replace the lower plug and presto! i have a fully functioning engine for a limited amount of time. From the posts i have read so far i have seen what appears to me to be a multitude of possibilities, but given my limited experience with engines i am not certain of anything. My first inclination is to assume a problem with the coil but<br />my problem with this is that i believe the coil would have been completely shot by now instead of continuing the same routine. Am I wrong here? Also, i have tried to determine whether or not there is any water getting into the cylinder but i have not been able to locate any yet, although it is a<br />possibility. That's about all i know to tell you. Please consider my problem and give me any advice that you can. If you have any ideas or suggestions please send them my way. Thanks so much.
