1970 Evinrude 60HP Model no. 60073D
I attempted to run this motor for the first time since I got it and did get it running but not easily.
I have replaced the following parts:
Amplifier, Coil, Sparkplug wires, Rectifier, Points, Thermostat.
I have rebuilt the following parts:
Lower unit, Carbs, Fuel Pump, Starter, Remote Control wire harness.
Motor is getting Good spark and Fuel.
Now according to the forum guide on a cold start it says to have the throttle at fast idle with choke applied. My motor will not crank unless the throttle lever is all the way to slow. When it is in this position the distributor base moves toward the rear of engine. Is this retarding or advancing timing? When the throttle lever is moved to start the distributor base moves toward front of engine and the switch under the flywheel is no longer depressed disabling start. Engine will not start with throttle lever in slow position so I don't know what I am supposed to do.
I am very new to this as this is the first outboard I have ever owned.
I have Solec & OMC manual for this motor but I just want to learn the basic theory of what is going on so I can work better at fixing this.
