I need help setting up a sound system in my boat!!!
ry
Hi, i am looking at putting a sound system in my boat. (17.5 feet) I already bought
http://www.canadiantire.ca/AST/brow...Stereo%2Band%2BSpeaker%2BBundle.jsp?locale=en
(bought in on sale for $170) and am thinking of getting 2 pairs of these speakers
http://www.amazon.com/gp/product/B0...&pf_rd_t=101&pf_rd_p=470938811&pf_rd_i=507846.
I can get a good deal on this amp http://www.bossaudio.com/main/917#
I'm planning on selling the speakers I got with the receiver on kijiji and only using the MB Quart speakers. Then hooking the speakers up to the amp like the first result on this page:
http://www.google.ca/images?q=2+cha...&source=og&sa=N&hl=en&tab=wi&biw=1280&bih=685
Will this work for me? Is there another route I should take instead? Any tricks/tips are appreciated as this is my first time doing anything like this. Thanks so much for the help, I really appreciate it!!
Fed up
Re: I need help setting up a sound system in my boat!!!
Car audio is my thing, so i might be able to give you some insight. The speakers look good, along with the head unit, and audio amp, the speakers are rated at 60 watts-120 watts RMS power, this is what they will need to sound their best. My rule of thumb has always been to hit the rms power rating in the middle. So we are going to say that you need 90 watts of rms power. the Boss amp will give you 125watts rms at 4 ohms. This is a good number. and should provide you with what you are looking for as far as the sound goes.
Here is my suggestion on setup- Use quality grade RCA cables for your patch from the HU (head unit) to the amp, on the gain on your amp only turn it about 3/4 of the way up. You will always want some wiggle room for power. When you start maxing out your rms rating and your amp gain coupled with prolonged use at a high volume, it is like running an outboard at full throttle all the time. It will preform really well but lead to a quick kill of all the componets in the end.
when choosing your speaker wire dont skimp if it calls for 20 ga wire- use 16. in the case of wire for your speakers and going to the amp- bigger is better in the end.
I would suggest using foam baffles behind the speakers- this will help with the bass response from the speakers and keep them from sounding "hollow".. they are relitivly cheap and very effective.
The wiring diagram you posted is the way to go, hands down.
if you have any more questions please post them, i will do what i can to get you the information that is needed and requried
ry
Thank you so much!!! Exactly what I as looking for :)
NHGuy
Figure out the draw your components will produce, if it's more than your charge system produces you will want to take that into consideration.
ry, what kind of engine does your boat have? If it's an outboard it may need some power output enhancements or another battery. Generally speaking, the older it is the less powerful the charge system is. If it's a stern drive you may be able to run it as is or get a bigger alternator. Just make sure anything in the engine box is marine rated. Which means no exposed sparks.
Fed up
/|\ What he said. With that kind of rms power you will be pulling alot of juice from your battery. Not good if you dont like to paddle
LippCJ7
ry you can find alot of info for this stuff in the Electronics section of the forum which is probably where this thread will be moved shortly. Just FYI and welcome to iboats!
A dual battery switch, automatic charge relay (ACR) or Voltage Sensing Relay (VSR) is recommended anytime you run a high power amp in a boat. You don't want to be left with a dead starting battery. There is enough reading on this forum regarding dual battery setups to make your eyes bleed. Just search on "Dual Battery Setup" or similar words.
ry
ok, thanks a lot!!!
LippCJ7
Yeah as Silvertip said, also don't be worried about doing dual batteries its one of those upgrades I think that can't be understated just for the piece of mind, never having to worry about getting the boat started after taking a break with the tunes going... Its pretty easy to do and not very expensive either.
daverulz
Car audio is my thing, so i might be able to give you some insight...
Car Audio is my thing too I've got a bit to add here.
1. Where the gain is set is dependent on the preamp output voltage from the head unit, arbitrarily setting it to 3/4 is a good way to not do it. See my post here on how to set gains.
2. Speaker wire should be chosen based on the power requirements of the speakers and the abilities of your amplifier to deliver. 16 awg is pretty much the standard size recommended. But you can read more and find some handy calculators here. Laarger than 16 awg for anything other than high powered subwoofers is a pointless waste of money.
3. The foam baffles will do nothing for the sound of the speaker. They certainly won't improve the bass response. The few times I've used them I've found they suffocate the speaker killing any low frequency response. Others have done tests that show they are acoustically transparent. Regardless, they will do nothing to improve your sound. The best thing you can do is make sure that the front and back wave from the speaker are isolated from each other to prevent cancellation.
to the original poster:
I see a few issues that are worth noting. First, I'd stay away from the Boss amp. It's overated junk. I'm willing to bet you that it puts out much less power than is written on the heatsink (Boss is known for over rating their amps, it will probably put at 800 watts if struck by lightening) Also, that amplifier is a 2 channel amp from what I can make out from the horrible specs on their website. That's not to say you can't use it to drive 4 speakers, just that you'd have to run a pair of speakers in parallel on each channel.
Sony HU should be fine, as should the MB quart 6x9's. I don't know how much you're paying for that Boss amp, but as mentioned in the other thread I linked to, there is a pretty nice MB Quart at Sonicelectronix.com for a little over 100 bucks. Read my post in that other thread on wiring it all up too. In a marine environment you want to make sure everything is connected in a way that it is sealed (I like to use adhesive lined heat shrink) to eliminate the possibility of corrosion. Don't forget to budget for the wire either. Probably looking at between 50-100 dollars for all your wiring needs. I like to get my wiring from Knukonceptz.com.
As Fed up said, shoot off your questions, I'll do my best to help you to.
