Re: i need advice on an engine coupler replacement on mericruser 470
i would really appreciate some expert advice!!!!! obviously the engine will have to come out . do i need to remove the outdrive ?
Couplers fail because the engine and outdrive are not perfectly aligned with one another. The only way to align them is to remove the outdrive and use an alignment tool.
So to answer your question: you don't NEED to remove the out-drive to replace the coupler, but it would make it a whole lot easier, and on top of that, if you want you're new coupler to last, than you're going to want to align your engine, and in order to align you're engine, you have to remove the out-drive.
So.. What you need to do is:
Remove the outdrive
Remove the engine
Inspect everything (look carefully at the splines on your drive-shaft)
Change the coupler (lock tight)
Reinstall the engine
Align the engine (proper alignment tool)
Tighten down you're motor mounts (lock tight)
Verify the alignment
Grease the @#$@# out of you're coupler and splines
install you're outdrive
If you don't follow those steps, you will simply strip out you're new coupler.
And while you're in there:
Shift cable
Bellows
Gimbal bearing
U-joints.
IF you're going to pull everything NOW is the time to do all that stuff. Unless you're stuff is in perfect condition, change it.
