texasvet54
Thread starter- Joined
- Nov 5, 2010
- 267
I have a 1987 Three Buoys houseboat and I want to add a deck drain to the rear deck. Currently I have two drains that discharge through a thru-hull fitting in my aluminum hull. The original Volvo engine was replaced with a larger Mercruiser engine and I believe that is the reason that the current location is a little forward of where it needs to be. Water is pooling at the very back of the deck and it probably didn't before the engine replacement.
So, I'm looking for a fitting that will mount flush with the deck. I'll then add a hose underneath and use another thru-hull fitting for discharge. Can anyone point me to a good source?
Thanks,
texasvet
Thanks,
texasvet
